check sunroof drain to be clogged first,second area around cabin air filter, water has funny way of traveling once it gets into funky interior areas and ducting,
there are as stated, four drain points one in each corner of the sunroof, they are attached to hoses, the front two go down through the pillars and drain out a little rubber "bonnet" between the two door hinges, back two two somewhere around the rear wheel fender wells, you have to be careful if you blow air down thru them as any clogs will blow the hose off, I have a piece of 1/8" diameter nylon hose (semi rigid) which I snake down thru then with a little air pull back out as I go, I will try and remember, somebody told me about pouring something,not drain cleaner! but it dissolved the mold, ( paint and rubber safe)because that is what is probably in there, will post later if I rememberOkay, I'll check those tonight. I suppose it's possible that a leak from the sunroof could travel down the right side A-pillar and get behind the dash. Is that the common route of sunroof leaks?
Thanks, I double checked my work on the pollen seal and I'm now pretty sure it's the sunroof. we have a major rain storm coming in tonight so I'm going to cover the sun roof with plastic for now and try to fix the drains when the weather improves. Thanks for the help!there are as stated, four drain points one in each corner of the sunroof, they are attached to hoses, the front two go down through the pillars and drain out a little rubber "bonnet" between the two door hinges, back two two somewhere around the rear wheel fender wells, you have to be careful if you blow air down thru them as any clogs will blow the hose off, I have a piece of 1/8" diameter nylon hose (semi rigid) which I snake down thru then with a little air pull back out as I go, I will try and remember, somebody told me about pouring something,not drain cleaner! but it dissolved the mold, ( paint and rubber safe)because that is what is probably in there, will post later if I remember
That's a start, but the hoses are long and fragile - proceed carefully! No compressed air, no harsh chemicals. Mine have never clogged, but I hear of people carefully working a brake cable core through them.Can I just open the sunroof to access the drain holes? I'll check my trusty service manual as well to see how to get to them.
So brief update. I've fixed the water intrusion by clearing the drain tubes and cutting the drain nipples in the door jams. So far we've had a few major rain storms and no more water intrusion.Have same but a 2003. Had the roof drainage problem occur but on driver's side and into that foot well .... corroded all the soldered connections in a control module under that carpet. Had take driver's door column apart (caution air bag) to clean and reconnect vinyl drainage tubing to its upper and lower slip-on fittings. No damage to CM itself - just had to re-solder its wire connections. Understand there's also a CM under the right side carpet so good to catch this problem before CM problems arise.
Thanks for the advice scotts13, I followed your instructions and got the problem solved!!!That's a start, but the hoses are long and fragile - proceed carefully! No compressed air, no harsh chemicals. Mine have never clogged, but I hear of people carefully working a brake cable core through them.
Oh, and check the ends that come out in your door jams. Someone probably took care of it already, but dealers were instructed to cut off the "slit" nipple, leaving a round opening. If they're still there, squeezing your car's nipples may yield a rush of fluid...
