1 - 3 of 3 Posts
Right, my car is still leaking, i've found nothing in the engine bay that could cause the problem, so i removed the back seats as they were soaking through also.
Right, there is a pool of water ontop of a gromet where the wiring passes through the bottom of the car on each side of the underside of the back seats, is this the wiring for the brake pad sensors? Is it possible for water to breach the grommet if its not sealing??
Do you have a sunroof?
Rear brake pads don't have sensors.
1 - 3 of 3 Posts
