If you can't wire it properly to the Euroswitch wiring, you can tap it to the dimmer switch like I did. I got mine from Evolutionsports.com
Wire properly to the Euroswitch? You tap into the harness that you headlight switch (US or Euro) plugs into.
Taken from ECSTuning W8 Overhead Light Installation Instructions:
Locate pin 17 on the harness connecting to the light switch. Using the supplied Scotch-Lock, tap into the the GRAY wire with BLUE stripe coming from the #17 location. Re-Install the headlight, wait till dark, turn on the lights and feel the love.
Sorry, yeah I should have said the harness. I just pulled out dimmer's harness and tapped into its gray-blue wire.
