1 - 10 of 10 Posts
I noticed my VW symbol on the back of my car was getting kind of loose lately. Dangerously loose, so I went ahead and pulled it off so I wouldn't have any chance of losing it. What kind of adhesive should I use to attach it back onto the car?
What time is Matlock on?
3M double sided automotive tape....several strips to line the back should do the trick.
trailrunner said:
i've been considering shaving the emblem on my '01 passat. is it just held on there with adhesive? no clips or screws?
That's pretty much it. Not sure if you're aware though that the emblem sits in a recessed area so if you pull the emblem, you're going to need to have the area filled (I'd have it done with a metal piece welded on and then have the whole trunk resprayed).
1 - 10 of 10 Posts
