1 - 7 of 7 Posts
How long is the warranty on paint for VW's, I currently have an 01.5 and the clear coat on the trunk edge peeled off, the question is if it would be covered under warranty??
Paint is probably a "wear and tear" item. 12mo/12k. It certainly doesn't extend beyond the B2B, which you are probably also out of.
SirWired
If your car has less then 100,000 miles you can probably get VWoA to goodwill the repair. Either way, it shouldn't be terribly expensive even if you have a shop do it for you as long as it is contained to the trunk area. If you think other problem areas are appearing, it will be well worth your time to battle with VW to get them to fix it though (I bet you'd have luck... CC should last more than 5 years!)
1 - 7 of 7 Posts
