Hello everyone,
I have a VW Passat B3 from the year 89, I have never had any problems with it until now. After not driving it after some time, when using it I have noticed the clutch pedal quite loose (there is no oxygen in the circuit, nor losses) until after several changes I have lost the possibility of changing gears since it dont enter even with the pedal depressed to the bottom.
We changed the two cylinders, both the slave and the master, new hose and new liquids and cleaned the oxygen circuit.
But the problem remains the same, when pressing the pedal it is very soft and does not give enough pressure. In fact, after this we think that the diaphragm could have already been damaged by so many kilometers, so we also changed the entire clutch with a kit compatible with the model.
The fault is still there, even having changed all the parts corresponding to the circuit. Right now, it is in the workshop gathering dust, because nobody knows what the fault may be.
