Hi all.... anyone else had this weird situation... my wifes car...2004 passat 1.9 tdi diesel engine AVB:-
Prior to overheating ( wife run the coolant low) the car always stayed bang on 90º C normal temp.
1. Engine unstable temperature...found some problems..head gasket leak - changed that. . no longer air in the coolant .
2. Have changed thermostat ( twice ), New radiator, coolant sensors ( both.- green one twice ), waterpump ( twice ). Bled coolant system with vacuum
equipment, including the heater hose. with car lifted at the front, & rear.
Result:- car runs, start & drives well. I use an "Icarsoft" diagnostic CR Pro to monitor all functions while driving up & down hills & on flat roads.
Problem:- Temperature varies between 88 - 89º, & long uphill climbs to about max 93º . THis is the result I get from the diagnostic monitoring.
- The temperature guage in the dasboard shoes something else :- during warming up ( from coldstart ) the gauge reaches 90º before the coolant temperature
is at around 60 - 70º . The temp gauge then stays stable at 90º until a hill climb when it then increases to 100-105 on the gauge.
Does anyone experience this on their passat? BTW..when I read off the Coolant temp on my Icarsoft, the engine temp shows 90º, When Iread off the Icarsoft for the dashboard temp- it shows 109º.. Am I doing something wrong here??
