1 - 1 of 1 Posts
After that my car started to gave the check brake pad light, I changed the front brake pads which only have the sensors.
Since the female connector from the dashboard on the right side was damaged, I removed the connector on that side and hard wired the wire to the wire from the dashboard carefully and insulated it.
I still get the brake pad light on, I suspect its the other side of the car where I have to clean the connector.
May I ask if joining the wiring from brake pad sensor to the wiring from dashboard without the plug and socket helps or not ..
1 - 1 of 1 Posts
