Hey there, I still cant get my 2001 Passat AWM motor cranked up......It turns over, but doesnt start. I have good spark, fuel and air.
I got a cable and the VCDS lite program and it is hooked up, but I'm not sure what I need to be looking at. The only code that is showing up is
VCDS-Lite Version: Release 1.0
Thursday, 02 July 2015, 13:03:23:0
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77
Address 01: Engine Labels: 06B-906-018-AWM.LBL
Controller: 4B0 906 018 CM
Component: 1.8L R4/5VT G 0010
Coding: 0016551
Shop #: WSC 07134
2 Faults Found:
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 002 - Lower Limit Exceeded - Intermittent
16622 - Shareware Version. To Decode all DTCs
P0238 - 001 - Please Register/Activate - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 3B0 927 156 AH
Component: AG5 01V 1.8l5VT USA 0810
Coding: 0001104
Shop #: WSC 07134
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.LBL
Controller: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00021
Shop #: WSC 00028
So basically, in a no start condition, what would I look under for any issues?
Thanks for the insight!!
Coding: 0016551
Shop #: WSC 07134
2 Faults Found:
Coding: 0001104
Shop #: WSC 07134
Coding: 00021
Shop #: WSC 00028
