Does any one know how to remove the vanity light? I broke the lens and now the wife is upset and wants it fixed. You know how they can be.
Thanks
for your entertainment...
You have to use a flat screw driver to push in a metal spring clip and once that is fully depressed, pull down and out if comes with a little plug attached.
Not sure what end cuz on mine they were all different. IIRC, drivers side is on the right, passenger side you push on the left.
I just did this the past weekend and almost broke the lens too. Yes, the blade will go between the light and headliner and should be on the side closest to the center of the car , near the map lights.
BTW, on mine the light and wiring were fine so I think the problem is buried deep inside the visor, for me I'll live without it unless the homelink dies too. Mark
