1 - 1 of 1 Posts
i just got my vagcom yesterday and only had a few minutes to hook it up last night. i did a quick code scan, and am a bit worried by all the codes i got back.
i just bought the car last week - an 02 w8 wagon with 43k miles. i checked its service record (which looked pretty clean) and had my mechanic look at it before purchase and all checked out ok. everything in the car appears to be working properly (except where noted below) and there are no warning lights on the dash. but it seems like i've got codes coming from everywhere.
i try to do as much of my own work on my vehicles as possible, but i have no experience with vw's, and not much experience with automotive electronics. i'm going to record these codes and clear them to see if they re-appear. i saw that there were more screens in vagcom, but i haven't had a chance to check it all out yet (i'll have to wait until tonight to play with it some more). will i be able to get more detail on these problems by digging deeper with vagcon?
what else should i be doing to diagnose these problems? please have a look at my codes [[[and comments]]] below and let me know what you think.
thank you...
...j
VAG-COM Version: Release 607.3-UD
Friday,27,October,2006,00:10:15
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN Number: WVWZK63B82E382396
Address 01: Engine
Part No: 07D 906 018 E
Component: B5S-4.0L-AG-LEVG 4598
Coding: 00173
Shop #: WSC 00017
WVWZK63B82E382396 VWZ7Z0A4558009
2 Faults Found:
16840 - EVAP System: Very Small Leak Detected
P0456 - 35-00 - -
[[[i got a check engine light right after bringing the car home - i read and cleared a p0456 'Evap emission control system leak very small' with an odb2 scanner. i think it was just the gas cap, since it hasn't reappeared in about 800 miles since.]]]
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 0000
[[[no idea what this is, but i can tell you that maybe 5 times we have tried to start the engine and had it not start on the first try. i thought we were just not engaging the starter long enough (we're still getting used to starting an engine that we can barely hear) and in these cases it stated right up on the second try. could the immobilizer be failing and preventing the car from starting on the first try?]]]
Address 03: ABS Brakes
Part No: 4B0 614 517 AA
Component: ABS/ESP allrad 2329
Coding: 05397
Shop #: WSC 05311
1 Fault Found:
01119 - Gear Recognition Signal
[[[i've had no noticable problems with abs, and no warning lights. what's up with this?]]]
Address 08: Auto HVAC
Part No: 3B7 907 044
Component: CLIMATRONIC B5W8 0005
Coding: 27210
Shop #: WSC 05311
4 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-00 - Faulty
01272 - Positioning Motor for Central Flap (V70)
37-00 - Faulty
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
27-10 - Implausible Signal - Intermittent
[[[i was expecting codes here because i can hear the flap servos for the ac system clicking in the dash - they are barely audible, but are going almost constantly. but i'm surprised to see that its reporting all three servos have failed, as well as a problem with the control module - it seems unlikely that all three motors would fail together. could this be a controller problem instead?]]]
Address 15: Airbags
Part No: 1C0 909 605 C
Component: 0C AIRBAG VW61 04 0001
Coding: 12355
Shop #: WSC 05311
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
[[[again, no noticable problems and no warning lights. what's up with this?]]]
Address 17: Instruments
Part No: 3B7 920 946 E
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 23236
Shop #: WSC 00000
1 Fault Found:
01176 - Key
[[[no warning lights, no noticable problems - what's up with this?]]]
End --------------------------------------------------------------------------------------------------
1 - 1 of 1 Posts
