besides troubleshooting, changing transmission to sport mode and changing unlock to single press of button is there any other performance mods I can use my vag-com for
TIA
4th Gear (Wax on Wax off)
Yeep... you can drive up to my house and change mine to the Sport Mode.
When you are done at Jesstzn's house, I could use the same setting modification too. :poke:
I think you can also change the behavior of the alarm settings as well. I believe it also may provide near real-time readouts of various engine components. You might dump that into troubleshooting.
I turned off my door beeps - lets my 5mo twins keep sleeping while i open the trunk.
Real-time datalogging (approx 3 measurements/second) is pretty useful... particularly ignition timing vs. rpm & intake temp and requested boost pressure vs. measured boost. Just remember to keep your eyes on the road, not the laptop.
oh... there's also wallet performance: dealer said i needed a new throttle body -- vag-com said i didn't. TB adaptation and 30,000 miles later, vag-com is still right. (saved $400+).
What exactly IS a throttle body adaptation? I've heard it mentioned several times, but I still don't know exactly what it does. Thanks,
Jonathan
