1 - 7 of 7 Posts
I have discused this before but I have just recieved a Vag-com in the mail so i thought i'd test this out (btw, if u dont have one, get one, its worth it). So ive been getting a check engine light and when i pulled the codes i got this:
P1128 Long Term Fuel Trim mult.,Bank1 System too Lean
P1137 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
And about a week ago when i reset my check engine light (after i changed all 4 vacume lines) the two codes i were throwing were P0171 and P0172. Unfortunatly the light came back on and I got the first two codes i showed you. So my suspicion was (after reading the forums) that it was the MAFS. Below is the data I loged, please tell me what you make of it. Should't my "air mass in" be alot higher? (2001.5 1.8T AWM, Wett chipped).
Idle Speed Engine Load Inj. On Time Air Mass In
740-920 rpm 15-25% 2.0-4.0 ms 2.0-4.5 g/s
/min % ms g/s
3320 58.6 8.16 37.83
3640 70.7 9.86 50.5
3960 77.4 11.22 64.19
4480 88 13.6 81.25
4960 92.5 14.62 89.28
5360 91.7 14.62 94.03
5760 88.7 13.94 96
6120 82 13.26 94.92
6440 78.2 12.58 95.78
6720 107.5 16.32 94.42
6800 48.1 5.78 46.17
6840 37.6 5.78 44.58
Founder of the STFA
Dead maf sensor.
Looks like im gona have to start lookin for a MAFS online. Anyone think that i will notice a difference in performance other than hopelly remeding my check engine light once i chage it?
Founder of the STFA
Depending on your mileage, I think you're covered by a recall on the maf. My recollection is it was 70,000 miles but I can't remember if AWM was covered.
I had same code....
I changed my o2 sensor, then I cleaned the MAFS, the check engine light went away in two days.....
Thank you...................... PassatWorld Forum
how much is a vag-com? is it a tool one can purchase like an obd2 reader, or is it just an interface that you need a laptop for...?
1 - 7 of 7 Posts
