if an error was logged because of a particualr part that needed replacing.. (of which you then replaced)... do you need to clear the error before you get benefits from the new part?
in other words... e.g. if MAF fails and throws an error. Then you replace the MAF with a new one. Do you get the benefits even without reseting the error with the VAG-COM? or would it make no difference until you clear the error?
i.e. does errors logged by the car ECU/computer accually restrict the car performance on particular areas until they are properly cleared and removed??
thanks!
Abe
thanks!
Abe
