I followed the instructions at the link below and after everything was replaced and I was ready to pull the pin that is already in place when you buy a new tensioner, I realized that the pin was too short, there was no way I could reach it or get a grip on it to pull the pin out, so, I took the tensioner back out and replaced the pin with some electrical wire that I had. Then, I re-installed the tensioner and when it was in place and ready, I used the 17mm to let the tension off the wire and then I pulled the wire out.
Without removing the fan there was not enough room to get my torque wrench and 10mm hex in there, so I just tightened it nice and tight.
Also, I assume it is recommended to put some sort of lock-tite on the 10mm hex?
https://www.passatworld.com/forums/b5-information-base/279585-how-v6-serpentine-belt-tensioner-replacement.html
