V6 - DTCs P3296 and P3262 still present after O2 sensor replacement last week
461 Views 17 Replies 5 Participants Last post by  khnitz
I originally posted this in the "What did you do to your Passat today?" thread, but I thought this specific question might get more visibility with its own topic:
After I replaced all four O2 sensor last week, there were a couple of DTCs that popped up after the emissions learn cycle: P3296 and P3262. I replaced all of the sensors one at a time, so it is unlikely that I swapped connectors...but, I had DTCs before I replaced them, too, and that was after I removed the sensors to install the new flex joints last Spring (and I thought those DTCs were caused by how I had to use an oxy-acetylene torch to get them out, at that time).
P3296 - DTC 16543 035 - Bank2, O2 Sensor2: Slow Response
P3262 - DTC 19718 035 - references
I read these with a VAG 1552. I have VCDS, too - I can hook that up as well, if needed (it was just quicker to grab the VAG 1552 off the shelf).
I'll have to dig back into some of the materials I have from when I worked on the VW/Audi OnStar units at Motorola Automotive in the early 00's - I can't remember if "035" meant persistant/present/static at time of reading, or sporadic (stored, but not currently present).
Any ideas or suggestions are appreciated! For now, I cleared the codes again and am letting my son drive it around and through another emissions cycle to see if they come back.
1 - 18 of 18 Posts
I couldn't find either of those codes in Ross-Tech, so I can't offer any suggestions. If you do use VCDS, whatever codes it gives you will be in Ross-Tech, and will give you possible solutions too.
Reactions: 1
The full codes read from the VAG 1552 were:
DTC number: 16543 P3296 035 - Bank2, O2 Sensor2: Slow Response /SP
DTC number: 19718 P3262 035 - references
Yeah, those were the 2 that I searched for and the closest I got was :
16544/P0160 - Ross-Tech Wiki
and
OK, I'll have to see if I can get some live readings from the O2 sensor with the laptop, then, to try and better see what is going on.
Seeing that you have VCDS, you can run an adaptation sequence on the car and during that process it will test each o2 sensor and give the status as a pass or fail.
Pretty much takes the guess work out of it.
Granted it doesn't give you a graph, but it verifies the functionality of each o2 sensor.
I don't need to worry about it anymore as I now live well outside the required emissions test zone, but when I was required to have an emissions test done, I would run the adaption sequence.
It was a 100% accurate way of telling me if the car would pass the state required emissions test or not.
Reactions: 1
I'll give that a try! Maybe one of my solder connections wasn't as good as I thought, or I crossed a wire while I was working under the car with the soldering iron.
So, I connected VCDS and had a look - would this mean that everything is working normally now?
Rectangle Operating system Font Screenshot Technology
I would say yes. Everything passed and readiness is complete.
  • Love
Reactions: 1
Cool !
I was just nervous when the codes popped up after having just replaced the O2 sensors. I'll keep an eye on it (because it's not like my son would tell me if the Check Engine light came back on :censored:).
Now I can try and figure out what the little bit of rattling is when we start the car, the next time I get it back on the lift.
Correct. All is working just as it should.
FYI
If you use this as a tool to determine whether your car will pass emissions or not, make sure you put on the minimum number of miles for the learning process.
Off the top of my head I don't remember what that number is. I got busted one time because I went to the emissions station to early after resetting the codes and doing a readiness test.
If I recall correctly, it's somewhere around 70miles. We don't have emissions test requirements here in MI, but it was required in the part of IL where we used to live.
Reactions: 1
DTC 19718 You need to swap the places of the lambda behind the catalytic converter bank 1 with bank 2
Reactions: 1
Thanks! So far, the codes haven't returned - so they may have been left over from before the repair. But I'll update again after the weekend.
I don't remember if the plugs are the same and can be swapped. Surely the lambda is swapped.
DTC 16543 the lambda to be replaced is worn out
Lambda after 160,000 km may be worn out
Reactions: 1
I replaced all 4 sensors at the same time. I did it one-by-one, so I shouldn't have swapped the sensors when I replaced them. But, early last year I replaced the exhaust flex joints and took the converters off...so it may have been something I mixed up then. Anyway, my son has been driving the car (probavbly a couple hundred miles by now) since I replaced all 4 o2 sensors and cleared the codes again and they haven't come back...at least, as far as he knows. I'll check for codes again this weekend myself, to be sure.
These errors should not light the MIL (check engine) I wouldn't worry about it
Reactions: 1
The MIL is lit, again - steady, not flashing (I was able to look for it this past weekend). I'll get the codes in a bit and see if the same thing is being reported.
1 - 18 of 18 Posts
