Problem solved
Just remembered this thread and thought I should give it a happy and informative ending.
For anyone who may come across it:
This problem returned a few days later, I didn't return here because I knew that it was ignition
related (Any experienced person would if they had driven the car), people here were mainly
concentrating on fuel, and were getting tired of me. :banghead: Syndrome.
I had difficulty describing the symptoms well enough.
I was running the old Bosch Super Plus EGR7DQE plugs, which had been working fine, the condition
deteriorated, under light acceleration there were loud noises (like a cross between bang & boom) from the
engine compartment (seemed to be toward RHS), with each noise the car jerked as if the brakes had
been applied sharply.
I fitted new plug leads, and new NGK BKR6EKUB plugs.
Started it and idle was smooth, took it for a run, it was like a new engine.
It is still going without any problems.
The leads had carbon tracks (Which I couldn't see), and it was arcing down the sides of the plugs.
One of the two damaged new plugs, had fine grooves that you could see and feel, burnt down the
side of the porcelain.
I had checked in the dark with & without water, and saw no sign of light.
Here's another example of this problem:
http://www.passatworld.com/forums/42-volkswagen-passat-b5-discussion/357255-random-severe-clunk-while-driving.html
I think the noise was caused by the unburnt fuel (From a misfire) being ignited on the exhaust stroke,
and blasting into the intake manifold (The valve would be partly open), burning the fuel and blasting out
through the air-cleaner, and removing all the fuel and air from the entire intake system.
And I think the jerk was caused by all cylinders dying suddenly, due to the lack of air.
(These engines do fire on exhaust strokes).
I don't understand why this happens with this fault, but doesn't happen under other ignition misfire conditions.
And again thanks to all who tried to help. :salute:
