1 - 12 of 12 Posts
I currently have 235/45/18 tires.
What has anyone here upped the tire size to without a problem. That is staying with 18" rims.
Thx
Hello Kid,
a 255.40 is only 20mm wider than stock and .3 inches shorter or smaller diameter, but it's a lot of tire to put on an eight inch wide wheel; a 245.45.18 is .4 inches taller and a better fit as well as cheaper
not sure what the end game is but most of us try to stay with the same overall diameter. For instance, a 225/45/17 is the same diameter as the 195/65/15. This keeps the mileage and speedo correct.
The oem tire size of my 04 glx is 205.55.16. I'm presently using 225.50.17s, and gps tracking by phone app Waze suggest my speedo is reasonbly accurate. I any event, it would only be 4.2% faster or approximately 73 if the speedo reads 70. The difference I find with oversized tires is that steering boost feels diminished making parallel parking more work, but highway driving feels more secure.
Discussion Starter · #7 ·
Sorry, been away for 10 day trip. In any car I've ever had I always go one or two sizes up from the factory tires. On my former 2002 Jetta I moved up one size and the speedo was bang on. All VW's seem to have a built in HIGH reading on the speedo. My Passat will read 100k/h but the real speed is 96k/h. These speed readings are done with a GPS on nice long flat stretches of road.
I have no intentions of lowering the car, if anything I would prefer a bit more height since the Passat is a little lower than my Jetta was. I spend 5 1/2 months in Mexico during the winter and the speed bumps are horrible there. The Jetta would scrape across some speed bumps.
As GrandpaBill suggests, when the time comes I will get the 245.45.18 tires. It would be all four tires. The added 0.4 inches height would be a bonus for me.
Thanks for your inputs.
Discussion Starter · #9 ·
245/45 will not fit
May I ask you to elaborate on your statement?
My stock 235 x 45 x 18 tires are 9.25" wide and the tire wall height is 4.16"
On a 245 x 45 x 18 tire, the width is 9.64" and the tire wall height is 4.33" which makes this tire 0.39" wider and 0.23" taller (Actually the real TOTAL extra height would be twice 0.23 = 0.46 as GrandpaBill suggested.) Though it really only adds 0.23 extra ground clearance.
Oh wow. Ricers? We're not talking slammed. Just a little lower. Even 2" is still practical.
When I had my b7, it was laughably high. A 1" drop would've been dead sexy and everyday drivable in the US. I get why you don't need it, but claiming it is ricer is a but much.
1 - 12 of 12 Posts
