I received my caliuper stiffening kit about 3 weeks ago and quickly fitted it.The new pedal feel was great, and no downsides.Just what you want from a mod.
But..........................
I had started to notice a "tinkling" sound when driving on uneven ground (with the window open).With it shut, it was more like a heavy mettalic knock.
In fact it sounded just like a failing ball joint.
Today I checked the calipers and noticed play in them. The sort of play that would be heard if you were driving on un-even ground.
I removed the pins and noticed score marks and noticed play in the bushes. So, I removed all 4 and replaced the old bushes and pins.
When I road tested the car, the sound was gone. Ok , so the pedal feel was not as good either.
So, if you are considering this mod beware.I'm sure there are many satisfied customers, but I re-think is required on this one !
The original rubber bushes do allow movement ( which gives rise to the pooer pedal feel), but this movement is not transmitted to the car as noise.
I guess I'm the only person who has suffered this ? However the only change I made to my car today removed a noise that only started post mod.
