1 - 20 of 26 Posts
I've got an obnoxious rotating, clicking noise from my front pass. side wheel well. I tore the boot a year and a half ago and it started to click. I got it repaired but dont remember if the clicking went away, but I know its been there for a while now! :mad:
Could the old tear be causing this!? Is there any way I could add grease to the CV Boot?
TIA,
Ryan :)
CV boots don't click. :) Once they tear and fling all the grease out of the joint it depends how long you run it like that to tell if the joint is ruined. Doesn;t take long for your joint to be ruined. Sounds like your outer CV Joint is. You can add grease but you have to pull the axle off to get to the inner joint componenets and that will probably only postpone the inevitable. At that point you should just replace the whole axle as your problem will return. Good luck Ryan!
Several people have gone through http://www.raxles.com/products.aspx before with good sucess. I believe stock replacement is like 180 with a high performance beefier one goes for 240. Give him a call. Dealer price is like 500 bucks a side.
Here is a good read about split boots.
http://www.raxles.com/splitboots.aspx
".. and most importantly, a joint with a bad boot and contaminated grease may be damaged and need to be replaced anyway. It's impossible to detect certain types of cage damage and race wear without removing the joint from the car."
Good luck!
Re: "Clicking" from OLD CV Boot tear?
TIA,
Ryan :)
I'm with the same problem.... this sucks.... :mad:
Discussion Starter · #12 ·
I just ordered an axle from raxles.com, great guy, great service! Will let you know how the install goes next week! Any tips/tricks for the install, it looks preatty straight forward.
Ryan :)
Ryan :)
get the tools from autozone . . . . $13 for the 10mm triple square and $8 for the 14mm hex kit.
Dave
Discussion Starter · #16 ·
crew217 said:
Curry said:
thanks again Dave! :thumbup:
np . . . btw
REMOVE THE SPEED SENSOR BEFORE DOING ANYTHING
Just to be safe. I almost screwed it up when i started pulling on the axle. Then i realized I still had it in.
Dave
I read that in all the write-ups, but lets hope I remember it! :roll:
When I ordered the axle I was told that I can do this w/o pulling off the caliper and rotor. Did you do it that way? Or Is it easier to take them off?
Ryan
Curry said:
crew217 said:
np . . . btw
Dave
Ryan
Heh I have a BBK and I had no issues getting it out without removing the caliper and rotor.
Dave
1 - 20 of 26 Posts
