I checked my oil yesterday and there was a light colored petroleum gel on the top of the orange plastic piece on the dipstick which marks the top of the low/add range. It resembled petroleum jelly, but it was milkier and more liquid. The oil level was directly in the middle of the low/add range, so no problem there. I wiped the stick clean and rechecked it. This time there was no gel on it. Anyone have any ideas what this may be?
I check my oil every 1000 miles and have never seen this before.
1999 GLS V6 Tipronic, 43000 miles
Retired PassatWorld Staff
Sounds like condensation. No biggy. Will burn off when the engine is hot for a descent period of time. Did you by chance have a similar substance on the filler cap?
Small amounts of what you saw are OK... boat loads of it indicate a coolant leak, but it sounds like you just have a little bit, so no worries.
Thank you for the info. I'll keep tabs on it and make sure it isn't a recurring problem.
:b5: :thumbup:
Consider it a naturally RE-occuring phenomena. Particularly on colder day's (when the block is cold enough for condensation to form.
I'm sure the guys are right about what it is, but if your oil ever turns milky, it's a sign that water is getting into the system. Could be a blown head gasket. Just for future reference in case you start seeing more of this, or it comes up in the future.
