1 - 7 of 7 Posts
Re: Um, Impedence Help (Zero4875)
More details pls...
Is the Blaupunkt a split system?
The rear woofer? sub? mids the the doors?
Do you have an amp?
Generally, simple adding a resistor is a "no no"... as the resistance varies depending on frequency for the speaker, and the resistor(IIRC)... may be a cross-over system may help...
The best setup would obviously be a properly matched speaker and amplifier combination...
Mike
The 4 ohm speakers should be no problem for the Monsoon (or any amp), it will just take a little more power to drive them than the stock 2 ohmer's. Using more "rear" fade to balance the sound should do the trick.
Or you could bypass the Monsoon amp completely and cut the harnesses at the Monsoon amp. You'd need to buy crossovers though... And I have the pinouts of the Monsoon amp somewhere....
<BLOCKQUOTE>quote:<HR>Um, Impedence Help<HR></BLOCKQUOTE>
Viagra? Oh wait...
1 - 7 of 7 Posts
