1 - 8 of 8 Posts
I took off the belly pan for the first time today, intending to replace the DV.
First question: I saw this stuff. It doesn't look good. What is it?
Second question(s): In the picture below, the upper-left rectangle shows a clamp I don't know how to remove. How do I remove it, and even more importantly, can I put it back on again? I don't have a clamp that size.
The lower-right rectangle shows a clamp I've loosened, but the hose seems to be holding on nicely anyway. Are there any tricks to getting the DV out?
TIA
In the first picture it look like its all over the motor mount so it could be the goo from inside the mount, I thought it was more of a purple color. Also could be coolant if you have a coolant leak.
Second picture, The left rectangle is a one time use clamp, you have to cut if off with a diagonal cutters or snip of somesort. YOU WILL NEED A NEW CLAMP. Some times the hoses stick after being clamped that long so just stick a screwdriver in and run it around to break the hose loose of the dv.
Thanks Purplezr2. Here I thought all those clamps I bought back when would serve me when it came time to replace the DV, but now I see I need some much bigger clamps. What size clamps do I need? Does it make a difference what kind/where I get them?
[edit:] Is it time for new motor mounts?
check the info forum or search for past DV installtion guidesl...
1 - 8 of 8 Posts
