Looking for some help on this one. After replacing the fuse, the turn signals will work for a little while, sometimes 1 minute sometimes 2 miles down the road. Then they stop working. Hazards work fine.
I added a trailer wiring harness with those wire crimpers which seemed to be the beginning of the problem. I've removed it completely now, and the problem continues. I've taped over all of the wire cuts.
I've replaced:
Turn Signal stalk/hazard switch
Turn signal relay.
Something is shorting out at higher speeds....probably causing higher voltage then the short.
Ideas on where to look?
Thanks
I've replaced:
Turn signal relay.
Thanks
