I installed a HKS Type O TT on my 05 1.8t and im having two issues with it.
1)Im pretty good with wiring and electronics so this one baffles me maybe someone has a solution. All the wiring was soldered and wrapped. The issue is that after i turn ignition off there is a split second where the motor is turning off the RPMs drop almost to 0 and then the TT kicks in and will engage the timer. I havent went back and done some checks with a multimeter yet but any ideas?
2)When the timer runs out the car turns off fine. I understand you must manually lock the doors but the radio then does not turn off. If the timer runs out, i lock the doors and leave it be the radio(aftermarket Pioneer AVIC) will stay on. Only if i lock the car again with the FOB or put the key in will the lights flash, horn dings, and radio turns off.
Thanks for reading and input, looking to fix this in a few days :thumbup:
