1 - 2 of 2 Posts
Im looking to get a turbo timer harness for my passat. Do any of you know where i can buy one. I really don't want to start cutting wires to put the sucker on.
The other questions is can i run the K04 with the k03 software till i get money to have it done? I can't just do everything at onece.
I never found a suitable harness. You're just going to have to cut and splice. This is my writeup -- http://www.passatworld.com/forums/showthread.php?t=224405 -- no pics, but as much detail as I could stand to write. If you need pics or ideas of places to install your timer, you can find plenty of other writeups online. HermanH has a good one on how to tuck the timer into the little slot to the left of the handbrake.
If you're going to run the K04 with K03 software, you should consider buying a manual boost controller and connecting it in parallel with the N75 valve so you can make sure the K04 doesn't boost more than you're comfortable with until you get the proper software.
1 - 2 of 2 Posts
