1 - 7 of 7 Posts
Where does it leak oil?
- Inside, noting burning oil from the exhaust?
- Oil Inlet side of the turbo ?
- Oil return line of the turbo ?
If it is one of the last two, it is simple repair. The inlet line is a copper O ring that will require two wrenches remove the line itself. The return line is harder to get to (removing the AC compressor helps) and is a metal gasket, with 2 6mm allen screws holding it into place.
The job (replacing both) should take less than a couple hours!
What would be the way to determine if it's either of the later 2? I have an oil leak that I can't seem to place but have noticed oil on the bottom of the oil return line (driver's side of oil pan).
Can you tell if the oil is streaming down the return line, or leaking right from the pan ?
if it is streaming down, you will most likely need to replace the metal gasket on the bottom of the Turbocharger that goes between the turbo, and the return line.
1 - 7 of 7 Posts
