1 - 7 of 7 Posts
How would I find this specific TSB? I've searched the web...:salute:
Any pointers on how to attain this?
I've read it's possible to pay via a site but all the ones I've seen seem to be a bit wishy-washy.
When found in VW Passat (3B): 5-Speed Automatic Transmission (01V), check Transmission Sealing (see TPL 2009761).
The NAR (North American Region) TSB 01-07-22 or 2011908 should contain similar information about the internal torque converter seal failure.
17125/P0741/001857 - Torque Converter Clutch: Stuck OFF / No Power being transferred
Possible Causes
Automatic Transmission Fluid (ATF) Level not OK
Transmission Sealing faulty
Automatic Transmission Fluid (ATF) dirty
Torque Converter faulty or incorrect Torque Converter installed
Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218) faulty
Torque Converter Pressure Valve faulty
Valve for Torque Converter Clutch faulty
Torque Converter Lock-Up Clutch faulty/worn our
Possible Solutions
Check Automatic Transmission Fluid (ATF) Level
Check Transmission Sealing
Check Torque Converter
Check Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218)
Check Torque Converter Pressure Valve
Check Valve for Torque Converter Clutch
Check Torque Converter Lock-Up Clutch
Special Notes
When found in the NAR (North American Region) Audi vehicles with the 01V/01L family transmission check for similar torque converter failure issues explained in TSB 32-07-02 or 2010879/10.
Category: Fault Codes
The only items that seem to relate are complaints that are related, but I don't see anywhere that a TSB would be available.
I've read here and there that the TDI B5.5 was possibly excluded from this specific TSB of power train issue? Which is maybe why I'm not finding it here.
What are you trying to do with this info? It's beyond any warranty and since it was not a recall, it would not be covered. The seal on the locking mechanism fails in 99% of the cases. The more power/torque or the more stress (4Mo), the earlier the failures. The B5 S4 and W8 were the worst. The TDI and 4Mo also had this issue. Even the FWD gas engine had them, just not as low mileage. My V6 4Mo was just around 110-115K when it failed.
My intent is to either diagnose/confirm it's the TC or pass the correct info onto the next shop I bring her to.
Current VW dealership states they never go out, have never seen it, etc. (still waiting to have them either give status report or release car back)
I have a feeling I'll hear "new transmission" when it could be just the TC.
VW dealership is lying. Like I said, it's at least 99% that the TC seal has failed. I've actually never seen or heard of any other reason for the failure.
1 - 7 of 7 Posts
