I did a transmission swapping from 5hp19 ecb to 5hp19 dss and got an error p0716-g182 implausible signal.did some research and just learnt that g182 sensor was changed from induction to hall after 2000.5hp 19 ECB transmission has a hall type of sensor,
Question 1:can some one tell me which type of g182 sensor 5hp19 DSS has?
I have gone through ETKA checked valve body and both have the same sensors but a clarification would help?
Question 2: does the TCU year of make matter..im using 8D0 927 156 AQ year 99..going by what i found out about the g182 sensor inductive<99 hall>2000 is the TCU the cause?
Question 3:i have the original ECB tcu which is a 4wheel can i use it if things hit the fan?
Question 4:any work around that wouldnt involve changing a transmission?
NB.
-No error code in Engine
-i checked on data stream and g182 was measuring from gear 2..gear 1 and parking value is 0
-i get stuck in gear 4 and slams me to safe mode
Error in tcu-p0716 implausible signal
