1 - 2 of 2 Posts
hi lads, I wonder anyone could give me a hand on this. My 01 passat estate (auto) transminssion went wrong after rain coming into my car, the car wont change gear. therefore, can anyone tell me where can i get a transmission control ecu in uk?:confused:
Did you pull the right side carpet up and dry out the TCM thouroghly? Also, check the any connections in the wiring harness and connector for corrosion and repair/clean is corroded. This might correct the problem.
1 - 2 of 2 Posts
