I got a 2000 Passat. Its got 59k miles and a manual transmission. the 2-3 shift is starting to grind if I shift higher than 3000 rpm, all other gears shift fine. Any idea whats causing this? I push the clutch all the way to the ground and it still grinds from 2nd to 3rd.
Any help appreciated. Thanks.
