Hey guys,
I had my ABS module fixed a month ago because of the dreaded beeping, ABS light, and traction control light were on. When I got the ABS module back and replaced it the ABS light and beeping went away but the traction control light didn't.
I finally got an official VCDS scan tool and scanned the car. There were no real problems during the scan aside from window regulator problems that I already know of. What could be the problem? How do I post the VCDS log on here?
Edit: Here's the log
Monday,01,October,2018,20:57:41:01076
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.1 (x64) HEX-V2 CB: 0.4436.4
Data version: 20180927 DS296.0
Ross-Tech: Home
Mileage: 183410km-113965mi Repair Order:
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 183410km-113965miles
Address 01: Engine Labels: 058-906-018-ATW.lbl
Part No: 4B0 906 018 BH
Component: 1.8L R4/5VT G 0006
Coding: 07551
Shop #: WSC 00028
VCID: 6889BBD8EB639807366-5160
No fault code found.
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 AN
Component: AG5 01V 1.8l5VT USA 3132
Coding: 00104
Shop #: WSC 00028
VCID: 79AFEE9C80C9118FD98-5184
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00021
Shop #: WSC 00028
VCID: 6491AFE8174BFC671AE-51F2
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 B
Component: 03 AIRBAG VW5 0003
Coding: 12339
Shop #: WSC 00028
VCID: 363525A0F1573EF774A-4B5C
Address 17: Instruments Labels: 3B0-920-xx2-17.lbl
Part No: 3B0 920 920 B
Component: B5-KOMBIINSTR. VDO V22
Coding: 07245
Shop #: WSC 00000
VCID: 1D67DA0C74A18DAF950-513C
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 02172
VCID: 70B9D3B8D3B350C76E6-5160
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 6W Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00028
VCID: 06559560C1376E77A4A-4B1E
Subsystem 1 - Part No: 1J1959801D
Component: 6W Tõrsteuerger. FS0002F
Subsystem 2 - Part No: 1J1959802E
Component: 6W Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811D
Component: 6W Tõrsteuerger. HL0002H
Subsystem 4 - Part No: 1J4959812D
Component: 6W Tõrsteuerger. HR0002r
7 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
01358 - Internal Central Locking Switch; Driver Side (E150)
27-10 - Implausible Signal - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
00915 - Window Regulator Switch; Rear Right; Driver (E55)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 B
Component: Radio DE2 0003
Coding: 04041
Shop #: WSC 00028
VCID: 1E65DD0079A796B78CA-51F2
End----------(Elapsed Time: 04:30, VBatt start/end: 12.4V/12.4V)-----------
Have you tried clearing all the codes to see if it comes back? It might just be a remnant from before.
For the VCDS logs, one way would be to just cut and paste them from a text file. I think VCDS will create a log file with all the results that is in text format. Just use notepad or something to open the file and then copy what you want to post (use CTL-C or select/edit/copy to clipboard) then use CTL-V to paste the text into a post. There might be better ways that will make the formatting better but that should work. Or take a screen shot and save that as a *.jpg file and then insert the jpeg file using the picture icon when you're making the post.
I think VCDS has a menu option or button to 'clear all DTC's'. Just use that and it will clear everything and should eliminate the light on the dash. Then drive the car for a while (a week works) and re-scan. If the light doesn't go off or if it comes back after a few days of driving you have a real problem. Otherwise, if the second scan looks good you are free and clear.
