Has anyone done this? The whole side of the car can't be held up with the stock jack right? I need to do it quickly (1500 mile trip coming up) but fear taking my BBS to someone else...
Thanks,
John
Thanks,
John
And a set of rhino ramps are dirt cheap too. climbing under the car without them for an oil change is :crazy:sirwired said:realbeentheredonethat,
Wouldn't ramps be a better solution for simple oil changes? Unlike the factory jack, ramps are built to sustain the weight of your car, and they are absolutely foolproof. They will also raise your car much higher than the factory tire jack, making the work much easier to do.
SirWired
Chas has an aluminum one in either the classifieds or the GB forums, or you can go to JC Whitney and get the crappy ABS plastic one for dirt cheap. If you're willing to wait a bit, I am trying to see what I can do for B5ers from my company on the ones we make too. Ours will be urethane so will be rigid enough to support the vehicle but won't damage the rails either.AgVWB5 said:Where can I get a set of those jack pads? I've got stands and a great hydraulic jack, but I don't want to use either without something protecting the car.
i use an oil extractor for oil changes...no need to get under the car.sirwired said:realbeentheredonethat,
SirWired
