1 - 8 of 8 Posts
what tire pressure should i have for max fuel economy? i have all of mine at around 30 psi. should it be higher?
For better economy increase it to 34 to 36 psi and check it regularly. Tire pressure will change about 1 psi for every 10 degrees F change. I find that the ride is not too harsh at those pressures.
I don't want to start a war, but I don't understand why people always say this. Maybe I'm wrong, but applying the ideal gas law, it seems like it should take about 18 degrees F (or 10 degrees C) to change the pressure by 1 psi. Here's my reasoning.
Say we start at 50 degrees F and a tire pressure of 30 psi. 50 degrees F is 10 degrees C, or 283.15 degrees Kelvin. Applying the noble gas law (Pv = nRT), and pretending the total volume of air inside the tire doesn't change with a small change in temperature, we can simplify the formula to P = T * some constant. At our selected temp and pressure, this constant is 30/283.15. Now reduce the temperature by 10 (which is 18 degrees Fahrenheit). This gives P = 273.15 * 30 / 283.15, which is approximately 28.9, or very close to a one degree drop in pressure.
So as a rule of thumb, it seems to me it's much more accurate to say that pressure change by 1 psi for every 10 degrees C change. If this analysis is wrong, please point out where I messed up. I've been using this rule myself for a while...
I don't want to dig out my thermodynamics book (I think I threw it out many years ago anyway), but it looks okay. I've always thought it was Fahrenheit. I found this with a google search (see link below):
A good rule of thumb is that for every 10 degrees Fahrenheit temperature change, tire pressure changes about 1 psi—higher as temperatures rise, lower as they fall.
http://www.gmgoodwrench.com/TipsAdvice/TirePressure.html
You have to base this on absolute pressure (gauge pressure + atmospheric, which is around 14.7 psi). So the pressure change per degree is larger than you calculated, and the 1-psi per degree F may be more accurate.
if you look at the gas cap door sticker ,it will tell you the PSI range you should be running in regards to loads/speeds/ if your not running the correct factory settings to begin with , cold temps will only increase the problems associated with under inflated /incorrect air pressure settings to begin with
Lefties have rights, too!
Yeah, it's the same as with the Arrhenius equation.
k=A*exp(-Ea/R*T)
Stability time is doubled for every 10*C change in temperature.
Oh wow; I didn't know that (obviously)! It looks like you're right; if I start at 34 psi at 32 degrees F and drop 10 degrees F, I get almost exactly a 1 psi drop. Thanks for clearing that up! :bowdown:
1 - 8 of 8 Posts
