1 - 1 of 1 Posts
Hello!! I have an annoying tire pressure light in the dashboard that first blinks and after a while lits solid yellow. Started to light when the winter tires were put on, as they do not have sensors in the valves. The summer tires are now on again, but the tire pressure lamp continues to shine. I also do not have the display where I can see the tire pressure on all four wheels and tire pressure selection is no longer under settings. This disappeared when the winter tires were put on. I've tried to do a factory reset but no difference made it. There is no reset button either in the center console or in the glovebox. I am supposed to reset by entering via the multifunction steering wheel and go to tire pressure and reset but that selection does not exist. Someone else who has had the same problem and has some good solution ??
1 - 1 of 1 Posts
