1 - 9 of 9 Posts
I have the Toyo Proxes 4 and was wondering what everyone is running in terms of pressure. They are at around 40 psi now, should they be more or less? When it was warm the other night they read about 42psi and yesterday morning in the cold they were about 38 psi. Thanks.
thats about what i run, 40 front, 38 rear. somewhere i read u should add 5psi for every plus size u go. i went up 2, so i added 10 psi to what it says inside my gas door.
Recommended tire pressures for my W8 sedan with 225/45/17 tires:
<= 100 mph, half load, 35 front, 32 rear
<= 100 mph, full load, 38 front, 45 rear
> 100 mph, half load, 39 front, 36 rear
> 100 mph, full load, 42 front, 48 rear
Your car is lighter, so you could use a lower pressure, I guess.
I run 39 front, 36 rear.
Thanks guys, I guess I have about the same depending on the weather it's right around what you guys are running!!! The chart is helpful larrs :thumbup: .
No Ricky you should fill them up to around 75PSI that should be perfect. :p :lol: :) :D :poke: :crazy: :wink:
I have 32 all around....2 Psi for each inch tthat i went up from the 15's.....
15=28,16=30, 17=32....dont know if its 100% correct,but i have good ride and they wear even
I know myself and Ronnie were running 39PSI on each tire but then again are cars are a lot heavier.
1 - 9 of 9 Posts
