1 - 3 of 3 Posts
How tight should this be...should it be as tight as the fan belt. i think that maybe the tensioner is going bad because of a slight grind noise just before the car changes gears (tiptronic). Also as to not rule out the transmission, how do i check the trans fluid. i cant for the life of me find anything to check or change it...
Years? Miles? Engine? Look in the informatin base forum on how to check / change ATF. There is no ATF dipstick. Well if the tensioner is going bad, you need to get it fixed now or severe engine damage will probably occur if the TB slips or breaks.
1 - 3 of 3 Posts
