Think these are next on my list. I notice they have a pinch bolt. Is this a nightmare in the same way the UCA pinch bolt is or are these easier to get out?
Unscrewing the outer from the inner can be tricky if they use a lot of salt on your roads. On older design TREs, the threaded rod is isolated from the end with urethane, so twisting the end won't work. Just clamp right onto the threads with vice grips. Grab the inner with an open end wrench. Copious application of penetrant helps.
