Finally i got all my boost leaks sorted out (at long last) but unfortunately my engine management warning light keeps coming on every time i re-set the battery and continue driving the car.
This doesnt really cause any probs other than the throttle plate half shutting sometimes, but in general it pulls stronger at a lower boost level than it did with the stock boost control valve. At 0.75Bar of boost it pulls harder than it did with the mapped 0.9Bar of boost, i presume this is down to the diode mod taking the timing curve on alot more agressive path?
No other problems it must be added, but i reckon the management warning light has come on because the boost doesnt spool up at the rate the ecu is requesting it at? :)
What engine do you have? Actually, it is the other way around, the boost builds up very quick and the difference between requested and actual charge pressure becomes too great. I think the ECM shuts the throttle plate to try to control boost. I'm having this same exact problem and if I don't come up with a solution, I might just go for the chip after all.
bostaph has since sold his Passat and gone for a Skyline - this post is quite old.
Thanks for pointing the good chap in the right direction! But i actually sold the skyline on due to poor 1/4 mile times and have since gone for a 320BHP evo 3 which is keeping me amused to say the least, I'm expecting great things from her!
