So last weekend I was struggling with my daughter's new to her 2004 2.8 Passat GLX. She bought it for $500 due to a broken timing belt. Car is in great shape, other than the timing belt and improper coolant causing the heater core to plug.
So anyway, I'm in the process of pulling the heads to replace all the valves and lifters and recondition the heads, just like I did for my other daughter's 2002 last year. The heater core flushed out nicely, and things were going well until...
Couldn't get the damn viscous fan clutch off...my VAG 3212 tool just wasn't giving me enough holding torque, and I actually bent it....the arms bent in the wide direction, not the skinny way if that makes sense...
So I bought a far superior tool than the VAG 3212. It's made by OTC. The 6613 Variable Pin Spanner Wrench made for Toyota cam pulleys. It has several different size pins, (VW needs 5mm pins), is very strong, and most importantly has a square hole on the end for attaching a ratchet or breaker bar. It took me about a minute to get the fan clutch off with this tool.
Anyway, just thought I'd share my success with this tool and that I highly recommend it over the VAG 3212 tool.
Anyway, I'm off to pull the heads, flush the block and radiator with a 50/50 CLR mix, replace all top end gaskets and seals, including the pesky coolant pipe O-rings and Kombi valve gaskets.
Anyone else have any tool recommendations?
Oh yeah, I want to share some advice someone on here gave me last year about pulling the heads on the 2.8. It's much easier leaving the exhaust headers in place on the heads and unbolting the 3 bolts that flange the header to the exhaust pipes and lift the head and exhaust headers in one piece than it is to try and unbolt the headers from the head while they're in the car.
