1 - 1 of 1 Posts
Looks like the trip to Phoenix took its toll on my 98 DD. :hmmm:
I knew I had flaky o2 sensor, but the rest of this, holy crap where to start?
I actually posted up about the 01358 drivers side door before but now, sheez, I'za got some issues.
I'm also suspect of that P0441 code. I just replaced the purge valve on the car a week before I went to Phoenix. By the way the road trip to Phoenix was over July 4th break.
I can honestly say, I don't remember if I cleared the codes after installing the new purge valve, so that just might be that easy.
I have a few spare O2 sensors laying around so I'll pop a new one in that'll be that.
The engine faults are not my concern, the other stuff is.
Known issues that I want resolved.
Since I put this car back together in spring of 2013 after swapping motors I've had the 3 airbag faults. Cannot for the life of me get those codes to go away. Actually the airbag light is more annoying than the CEL at this point in time :crazy:
The passengers side window goes up and down at will. Sucks when it's raining out.
When I use the physical key (don't have a FOB anymore) in the drivers side door, it will not electronically lock the other doors. You can feel the key locking the drivers side manually.
Along with this, the lock confirmation "chirp" is no longer present. It worked last year. The horn that makes the chirping noise does work though, I verified that by testing the unit directly.
For whatever it's worth, the master window switch panel was replaced with a brand new Genuine VW / Audi panel about a month ago.
98 GLS V6 5sp FWD
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 215290km-133775miles
Address 01: Engine Labels: 078-907-551-AHA.lbl
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR HS D01
Coding: 06101
Shop #: WSC 02645
VCID: 6CD73EBF1C9AEA2125-4AE8
2 Faults Found:
16544 - Oxygen (Lambda) Sensor B2 S2
P0160 - 35-10 - No Activity - Intermittent
16825 - EVAP Emission Control Sys
P0441 - 35-10 - Incorrect Flow - Intermittent
Readiness: 0000 0000
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 607 B
Component: AIRBAG VW3 S V03
Coding: 00066
Shop #: WSC 05311
VCID: 2C57FEBFDC1A2A2165-4B00
3 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance Too High - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 K
Component: 0G Zentral-SG Komf.0002
Coding: 04096
Shop #: WSC 05311
VCID: 4683AC1762B6F07193-4AE8
Subsystem 1 - Part No: 1J1959801B
Component: 0G Tõrsteuerger. FS0022
Subsystem 2 - Part No: 1J1959802C
Component: 0G Tõrsteuerger. BF0022
Subsystem 3 - Part No: 1J4959811B
Component: 0G Tõrsteuerger. HL0022
Subsystem 4 - Part No: 1J4959812B
Component: 0G Tõrsteuerger. HR0022
7 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
01358 - Internal Central Locking Switch; Driver Side (E150)
27-10 - Implausible Signal - Intermittent
01035 - Electric Window Thermal Protection Active; Passenger
35-10 - - - Intermittent
00936 - Electric Window Switch in Front Passenger Door (E107).
28-10 - Short to Plus - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
End-------------------------(Elapsed Time: 05:19)--------------------------
1 - 1 of 1 Posts
