Had to replace the battery in the car because it lost a cell and only had 10volts.
Installed new battery in the car and the remote lock and unlock function no longer works from the switchblade key.
Went through the programing steps in the owners manual and can not get the remote to connect with the car and function to lock and unlock the vehicle.
Swithchblade key in the ignition switch turned to the on position, reached outside and locked the doors with the valet key in the drivers door key hole and then pushed the button on the remote, waited and pushed button again, turned ignition to off position and the remote did not connect to the vehicle and lock and unlock the doors. Tried this a number of times and still no luck. I got the vehicle used, came with 1 remote and 1 valet key.
I replaced the battery in the remote about 3 months ago and even installed another new battery in the remote. Still no luck connecting to the car and functioning. Both batteries for the remote were showing just over 3-volts when checked with my Fluke volt meter. The remote had range of less than 10 feet to lock or unlock the vehicle, was like that when I bought the car 9 months ago.
Your help and input would be greatly appreciated. Do I need a new remote ? Do I need to go to the dealership to get the car and remote programmed/connected to each other ?
2002 Passat GLX Wagon 5-speed manual
