I had removed the sway bar and drove like that for quite some time. ( it feels smoother) as I decided to put it back on I realized that the inner edge of the front right tire is worn out considerably. Does driving without sway bar cause it? Or simply an alignment issue?
A sway bar is used to stabilize the car when turning or cornering. Both toe and camber will effect tire wear, if the car is at stock height it is most likely just an issue with toe
