hey im new here just thought id let yall know because i just got a 95 vr6 passat 5 spd. anyways everything electrical works on the car except the sunroof it will not open. is there like a fuse or something for it? any ideas on what could be the problem?
Lisa Simpson
Any number of things. It could be the rails, the motor, the cables (very common), etc. You should be able to find a manual crank for it buried under the access panel. If the crank doesn't work, the cables are snapped. If it does, the motor is dead or the switch is fried, or the fuse is bad.
Good luck.
ok i just noticed another problem. my stereo resets itself everytime i start up the car again. like it loses power once i turn the car off
