For some reason, there has been an epedemic of front sunroof drain hoses not draining due to the little anti-crud flap sticking shut.
To prevent this, open your driver's door. There is a black rubber thing in the hinge area that flattens out on the end, and points downward. Squeeze this thing with your fingers and make sure the flat part opens up.
Do the same thing on the passenger side.
If it makes you feel better, either snip the flat part off with a scissor, poke a hole in it, or put some silicone slickum between the flaps to keep them from sticking.
Do the same for the passenger side.
The rears cannot really be messed with easily, and I've yet to see a problem with one anyway.
Such a simple thing, but man does it ever save some heartache.
