VW passat 2016 TDI
Hello
What do you think about this mount?
I have clunks and after replacing sway bar bushes and links, outer tie rods and full control arm and still having those noises I suspect this mount.
Tell me what you think.
Is it come two mounts, one above the other right?
Thank you
Sent from my SM-N985F using Tapatalk
VW passat 2016 TDI
Discussion Starter · #2 ·
Update, replaced also inner tie rods and shocks observer, and still has this clunks when going over bumpers and road hole.
Guys I'm helpless please give me suggestions where to look for.
Thanks .
That "dogbone" mount certainly could cause some noises, but also check the tightness of all the subframe bolts.
VW passat 2016 TDI
How do I check the upper mount from the two of the subframe?
The 2 bolts that I saw that some people replace on there subframe already exist on this car?
Thanks
VW passat 2016 TDI
Update!!!
So the noise was from the struts bearings, but I replaced also the strut top mount and every thing is OK now.
Thanks everybody.
