1 - 20 of 27 Posts
I have the Audi A6 Strut Tower Brace: http://www.drewparts.com/product.asp?ProductID=440964
I think I paid around $80 last year (the strong Euro must have raised the price).
I did have to cut (with a hacksaw) about 1.5" off of one side of the aluminum bar, and then drill two new holes for the bracket.
It was really quite easy to install, but I put it in several times in order to 'gradually' get all my measurements correct prior to cutting/drilling.
Do a "search" to find out more.
Good luck!
I've seen a Sparco part, but I'm having a really hard time finding it. I believe there's also one from LLTek.
Good luck!
Don't forget our 20% discount with Drew ... use coupon "CLUBB5" at checkout
Will the strut bar profile fit in a W8 engine compartment? It is pretty well packed without much room for any additions.
Here is another of how the Sparco looks.
http://www.clubb5.com/forums/viewtopic.php?p=681961#681961
Word of advice on the Sparco bar though...You need to have the round brake reservour...not the iregular shepped (kinda looks like a square and circle intersecting each other) I added a pic showing the area of the reservour. That is the type you'll need to have in order to install it. Also you'll need to drill 4 holes (2 on each side) in order to totally secure the bar...or u can just use the 2 strut bolts and not drill.
Hope that helps. (as for where to get it...just goto any local rice shop or speed shop that carries or can get sparco products and ask for the sparco strut tower bar for the B5 A4)
just installed A6 tower bar, here are some pics
1 - 20 of 27 Posts
