Hi,
I have a quick question to you. Is your tweeter plastic case and rubber socket around the A-pillar also not perfectly in line with the window? I mean it looks like its not really tight between the glass and the rubber/plastic pieces:
You can see that the tweeter cover is close to the window at the bottom and then goes a bit away from it in the higher parts...
I would be most grateful if you could have a look on yours and check if it looks the same...
