1 - 18 of 18 Posts
Hey guys,
I've got a 99 with stock 15 inch wheels. What size tires are available for those rims. The last tires I got, I just stuck with what came on it, 195 65 R15. What are my other options????
Jonathan
d.passat00 wrote
what about 215/50's? would those work?
This size would be 0.5" shorter than the stock 195's, giving an approx. 6% speedo error, at 60 MPH indicated you would actually be going 6% slower. I'm also not sure how easy this size would be to find, my guess is your choices would be few, even 215-60-15's are not too plentiful.
Cheers Frank :) :drink:
Discussion Starter #9
What are the advantages/disadvantages of using the 215's versus the 195's with stock 15 inch rims??? Any difference in grip, handling, looks???
Jonathan
If your stock size is 195/65-15 then the 215/60 would be 0.2" taller yeilding a 0.07% speedo error, assuming your speedo is dead on accurate, when you're travelling at 60 mph indicated you would actually be going 60.4 mph. Speedo's tipically read approx. 1-2% high anyway, so as you can see the small difference in tire diameter should have no adverse affect.
HTH
the deal finder!
HTH
sounds good! guess i'll be getting the avs 215/60-15.
Discussion Starter #14
195's versus 215's
Are the 215's designed to fit my stock wheel and are just another option?? Or is this the kind of deal that, "it's not made for that wheel, but it will suffice". You know what I mean??? Also, if it's 1/2 inch taller, won't my already SUV suspension really look like Gravedigger??
Jonathan
Discussion Starter #16
My bad. I misread that. .2 inches is a different story. I still need an answer on the original question though. Were they meant for that wheel, or they just happen to accidentally work??
Jonathan
Jonathan
Tires are tested for different sized wheels and 7" adelaides should fall into a range of compatible wheels, ranging from 6" to 7.5" for say a 195/205/215 tire.
Also, take a look at 205 width tires, they will work well too. Behind the fuel door, there should be your stock size listed as well as an option is size which is 205 something I believe. Also note that different brands of tire will have different rolling dimensions even though they are the same advertised size so one brand of tire could be 0.2" larger another could be 0.2" smaller - so when you figure out what you want, check the specs.
1 - 18 of 18 Posts
