1 - 10 of 10 Posts
fully stock motor, including paper air filter and stock dv. only modification is the ARP 93 octane program. n75 was on the fritz so thats why its not very smooth.
That an ATW with a 5-spd manual, IIRC. Correct?
yeah it is, sort of. when i rebuilt the motor i used what we had laying around, so it has the atw head, aeb block, and rods and pistons from a motor with 19mm wrist pin pistons, so not an aeb or atw.
Resident a-hole knowitall
FYI - AEB and ATW are the same block, numbers look good though. i really should dyno mine before i install my new turbo.
I'm at work and I'd like to see your numbers but the firewall blocks photobucket. Can you post the numbers up and what your using for parts.
not to the wheels.....
Discussion Starter · #10 ·
if you use a 17% drivetrain loss, that would put the power at 194 hp and 252 ft lbs, which is close to what a chipped motor "should" put out. obviously every car is a little different.
1 - 10 of 10 Posts
